Difference between LA X1, X2, and a TC3000
la x1 does not have the removable assembly as the x2 does. Also I think the specs are a little different but not much. As far as the comparison to the tc3000 maybe different soft parts.
By removable assembly -
Do you mean if the X1 is a 15" it cannot be changed to a 12"?
Lets say I bought 2 blown 10" X1's, can I send them to TC or Team PSI and get them changed to 12"?
The motors are pretty much the same though correct.
Yeah the motors are the same but with the x2 you could by a top assy from tc, remove the old one very simply and put a new one on yourself. As far as the x1 you would have to contact them.
Our 3k motors have shorting rings to hinder flux modulation distortion, the LA motors don't have that feature.
both motors have the same gap ID so they will take 3000 top assemblies.
You can change to a 15" or a 12", makes no difference.
NEXT
NEXT
Belfry, Ky.
TC Sounds
