did i wire my sub wrong? dd9500 10"
subbin_n_da_rex
15's Strong
My current set-up is pioneer 9800bt , Orion 2500d , dd9510 d2 . I was trying to research but figured it wouldn't hurt to ask. i wired my dd from each voice coil to my amp straight (4wires from sub to 4 inputs on amp ) is it even wired right, i had my Orion hcca sounding like it was bumping better and I've got my dd break-en in already, its flexing but sounds weird. before break-in it was sounding way better so I'm guessing its wired wrong to the amp cuz its not bridged? need a Lil help new to dd subs so used to subs having terminals and wiring them parallel straight to amp. //content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
Is it a 2channel amp if so run the amp bridged(if bridgeable)(- from one channel+ from the other then)if your amp is one ohm stable hook the two+ on the sub together and the two- then to the amps - and positive terminals when your done you should have a left over - + one from each channel on the amp
For a clearer breakdown try Rockford fosgate's sight and click woofer wiring they have some diagrams
ok i was thinking the same thing my amp is one ohm stable 1 channel so its safe to run it bridged is what i was worried about, so two positives and two negatives are running to the amp what is that .5 .7 cuz coil config is dual 2.
subbin_n_da_rex
15's Strong
subbin_n_da_rex
Santa Ana
goingdef
