Diamond D3 ~ Memphis 16Prd 1.1000 ~ Audioque 1200D ~ WHICH ONE????
heres some specs
SPECIFICATIONS:
Double Sided Through Hole Epoxy PCB
Efficiency : 86% @ 4 ohm, at 100Hz
24dB/Oct Variable Crossover
Multi-Way Protection Circuitry
(Thermal/Over Current/Speaker Short/Speaker DC Protection)
Variable Subsonic Filter
Variable Bass Boost
Variable Low Pass Filter
Variable Phase Shift
Zero(0) Gauge Power Supply Connectors
Tested Voltage & THD : 14.4V & Less than 1% THD
Operating Voltage : DC 10V~18V
Digital Class-D Linkable Mono Block Amplifier
1 Ohm Stability
RCA Line Input and Master Output
24dB Octave Crossover Slope
Wired Remote Controller
PRODUCT MANUAL
Rated power output
----RMS power, 2 ohm linkable/dual mono
3000W x 1CH
----RMS power, 1 ohm mono
1500W x 1CH
----RMS power, 2 ohm mono 800W x 1CH
----RMS power, 4 ohm mono
400W x 1CH
Signal to Noise Ratio >90dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 40A x 4
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 252(W) x 58(H) x 434(L)mm
sounds petty decent
let me research some more!!
what u want for it? how old is it?
just wondering but just so you know i hate buying used shit!
SAZ 1500D is a very good amp. I ran 4 of them for quite a while. they'll run at .5 daily with decent electrical.
I installed the 1500's in moneybag's car and they're in very good condition. He's just stepping up to something a "little" more powerful...
show is at the store.
AQ and Sundown are 2 of the forum favorites and I've run both and would buy from both companies again...
With the "underground" stuff you get MORE for your $$$, so don't get sucked into the name brand thing.
If you want to make a drive down to Beach Park you can check out my AQ's and the Sundown in the GF's car. PM me if you're interested...
tuskilla
tuskilla
kenosha wi
tuskilla
