Diamond Audio D5 600.4
osl
Fully Regulated Power Supply
Up to 5V RMS Input Signal Voltage Capability
High-Pass Crossover: 12 dB/Oct. 50 Hz - 15 khz
High-Pass Multiplier: (x 10)
Low-Pass Crossover: Stereo, 12dB/oct. 50Hz - 5kHz; Mono (Ch 3/4), 24dB/oct. 50Hz - 5Khz
RCA Outputs
2 oz. Silver Plated Copper Circuit Board
Massive Proprietary Heatsink
Vully Variable Electronic Crossovers
Nickel Plated SOlid Brass, Circuit Board Mounted, 4 Gauge Device Power/Ground Connector Blocks
Nickel Plated SOlid Brass, Circuit Board Mounted, 10 Gauge Direct or Banana Plug Direct Speaker Connectors
Fly Cut Aluminium End Plates
Fully Adjustable Mounting Feet
Crossovers Employ Second-Order 12dB/Octave Butterworth Filters
Dimensions: 17" L x 12" W x 2-3/4" H
Number of Channels 4
RMS Power (4 ohms) 75 watts x 4 channels
RMS Power (2 ohms) 150 watts x 4 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 300 watts x 2 channels
Total RMS Power Output 600 watts
Peak Power Output 1200 watts approx.
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.02%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover N/A
Signal-to-Noise Ratio 100 dB
Bass Boost N/A
Fan Cooled No
Fuse Rating 30A x 3
$170/BO plus shipping
trades welcome but I'm only looking for bigger monoblocks or two crazy 10's or a beefy 12
shipping not included
osl
osl
minnesota
altendky
