Diamond audio d5 600.4 amp 150x4
drockstar
4 Channel 600 Watt Amplifier
Fully Regulated Power Supply
Up to 5V RMS Input Signal Voltage Capability
High-Pass Crossover: 12 dB/Oct. 50 Hz - 15 khz
High-Pass Multiplier: (x 10)
Low-Pass Crossover: Stereo, 12dB/oct. 50Hz - 5kHz; Mono (Ch 3/4), 24dB/oct. 50Hz - 5Khz
RCA Outputs
2 oz. Silver Plated Copper Circuit Board
Massive Proprietary Heatsink
Vully Variable Electronic Crossovers
Nickel Plated Solid Brass, Circuit Board Mounted, 4 Gauge Device Power/Ground Connector Blocks
Nickel Plated Solid Brass, Circuit Board Mounted, 10 Gauge Direct or Banana Plug Direct Speaker Connectors
Fly Cut Aluminium End Plates
Fully Adjustable Mounting Feet
Crossovers Employ Second-Order 12dB/Octave Butterworth Filters
Dimensions: 17" L x 12" W x 2-3/4" H
$175b+ shipping
drockstar
drockstar
Shreveport, La
audiophile831
