Diamond audio D3 1000.1 amp
serjr711.
Item(s) for Sale: ^^^
RMS Power @ 1 Ohm: 1000 Watts x 1
RMS Power @ 2 Ohm: 600 Watts x 1
RMS Power @ 4 Ohm: 400 Watts x 1
Pulse Width Modulated (PWM) MOSFET Switching Power Supply
Extruded Aluminum Heatsink
Double sided PC boards
Nickel Plated RCA Low Level Audio Inputs
Nickel plated, low resistance power and speaker connector blocks
Power ON and Protection LED Lighting for Easy Diagnostics
Thermal, Short Circuit, and Overload (Low Impedance) Protection
12 dB bass boost
Chassis mounted ATC/ATO type automotive fuses
High Current Output Capability (2 or 1 Ohm)
Internal 12dB/Octave Low Pass Filter (50-250Hz)
Bass Boost EQ (0 to +12dB) at 50Hz
Works flawlessly, few scratches looks; 9/10 4 gauge inputs, no bass knob, original box or manual.
Underrated amp,close to 1100 wrms.
Price: 150.00 shipped FIRM
Shipping and Miscellaneous Item Information: usps
IMAG0700 by cartman38, on Flickr
IMAG0694 by cartman38, on Flickr
IMAG0693 by cartman38, on Flickr
IMAG0695 by cartman38, on Flickr
I'm used to seeing the total RMS output at the bottom of the spec list, so when I glanced at your specs list, I went straight to the bottom number (400 watts) and then noticed 120 amps of fuses. I posted the comment "Holy high current Batman".
I adited it after re-reading the specs. "....." = nvm.
That's a good price for a 1k amp.
GLWS.
serjr711.
serjr711.
Antioch,Ca
Z1NONLY
