Up for sale are some things I have already posted and some that is new. Pictures of the components and subs will come soon. All these products are in mint condition minus one tweeter from the component set. It has a small imprint on the grille that doesnt effect its performance. Items, prices and specs are as follows:
New-Diamond Audio D3 12d4 Subwoofer- 105 shipped
Textured Copolymer Cones with Aluminum Dust Cap
Nitrile Butadine Rubber (NBR) Surround
Extra Heavy Gauge Stamped Steel Basket
Optimized Spider with Balanced Linear Suspension
Integrated Tinsel Leads
Venturi Vented Basket
Vented Pole Piece
Double Stacked Ferrite Magnet
Available with Dual 2 Ohm or Dual 4 Ohm 2.5" Voice Coils
Power Handling NOM/MAX: 400/800 Watts
Sensitivity (2.83V/1m):
86 dB SPL
Freq. Response: 25-250 Hz
Mounting Depth:
6.2 in.
Diameter:
11.1 in.
Used-Diamond Hex 6.5 Components- 165 shipped
# Cone: Kevlar/Nomex Sandwich
# Tweeter Cone: Silk
# Type: Component
# Crossover Included: Yes
# Drivers: Tweeter, Midbass
# Drivers per Channel: 2
# Power Handling: 170W RMS
# Impedance: 4 Ohms
# Sensitivity: 91dB (w/2.83-V input @ 1 meter)
# Freq. Response: 42Hz-22kHz (±3dB)
# Midrange
Mount Depth: 2-1/8"
Diameter: 6-1/2"
# Tweeter
Dia: 1"
Mounting Type: Flush, Surface, Angle
Used-Diamond Audio D600.4 amplifier- 200 shipped
# 75watts RMS x 4ch @ 4OHM
# 150wattsRMS x 4ch @ 2OHM
# BRIDGED : 300watts RMS x 2ch @ 4OHM
Used-Kenwood Excelon KAC-X20- 125 shipped
180 Watts x2 @ 4 Ohms, 250 x2 @ 2 Ohms RMS
1000 Watts Max Power
Glass Epoxy PCB Board for Better Sound Characteristics
Variable Low Pass Filter: 40~200hz -24db/oct
Variable High Pass Filter: 40~200Hz -12dB/oct
Optional Bass Remote
Infrasonic Filter: 15, 25 Hz at -18dB
K-Stat Transistor for Lower Distortion and More Detailed Sound
Dimensions in inches: W:14.9/D:11.2/H:2.5
Vented Pole Piece
86 dB SPL
Mounting Depth:
6.2 in.
Diameter:
11.1 in.
# Type: Component
# Impedance: 4 Ohms
# Midrange
Mount Depth: 2-1/8"
Diameter: 6-1/2"
# Tweeter
Dia: 1"
