Determine Ohm?
It's best to just use the math. Using a DMM will give you the Re or the DC Resistance, which is NOT the same as the actual impedance your amp will see.
How many subs do you have and what voice coil configuration are they?
To determine the final load for coils or speakers in series is like this:
R1 + R2 + R3 + R4 = Rtotal ; where R represents the resistance of each speaker or coil.
For parallel wiring, this is how you determine the final load:
1/R1 + 1/R2 + 1/R3 + 1/R4 = 1/Rtotal
It's pretty simple math and google can basically do it for you. You can also google calculators if you **** at math.
i believe your missing the numerator which should be 1. like this
at least thats what ive been taught. or maybe im misunderstanding you...or it could be that i didnt listen close enough when i was taught lol
the formulas are the same. The first versions leaves everyting as conductances (1/R). the second converts the form to give resistances.
im more visual so i guess it helps to see it as a "picture" if you will.
btw, nice quote in the sig. fox news //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
And the actual impedance varies by frequency, so a 4 ohm rating is really just a weighted average. Doing the DC resistance is just about as accurate.
95BlackGA
95BlackGA
Missouri
bose301s
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
