Desperate Wiring Help
carl6
When I Try To Install My New Car Stereo, You Can See The Power Button Light Up But When I Try To Turn It On, The Screen On The Cd Player Flashes For A Second Then Turns Off.... Is There Anything I Need Or Should Do So That The Power Stays On...... If N E Body Knows What I'm Talking About Please Share Some Knowledge Asap......thank You
Carl
first double check all of your power connections then check the fuse ( bad connection there ? ) if none of that fixes it un do it and run the 12 v switched 12v constant and ground straight off your batt if it turns on then its in your wiring if it doesnt turn on u got a bad deck
carl6
carl6
Boise, ID
lilmaniac2
