Sold Deka Unigy I 150's. Huge batts.
TaylorFade
I fail.
1. Product:
Deka Unigy I's. 150's. I only needed a few of these but ended up getting a pretty decent deal on the whole pallet so I have (literally) a ton of these I can't use.
2. Specs:
12AVR-150ET
■ Front access design for easy installation
and maintenance
■ Space saving Absorbed Glass Mat (AGM)
construction (48 volt system fits in 23" racks)
■ Tank formed plates optimize cell
voltage balance and performance
■ Reinforced case resists bulging and meets
safety requirements (rated 28 L.O.I.)
■ Computer-aided design and manufacturing control
processes and standards to ensure quality products
■ All batteries meet or exceed IEEE 485
and Telcordia capacity requirements.
■ Battery design and construction
meet UL recognition requirements
† Subject to change without notice.
SPECIFICATIONS
Nominal Voltage: 12-Volt/150 ampere-hours
@ 8 hr. rate to 1.75 final volts/cell
Positive Plate: Pure lead, low-calcium, high-tin alloy
Negative Plate: Lead calcium alloy
Post Seal: Epoxy-sealed
Terminal: Front access, 1/4" - 20 brass insert
Container: Flame-retardant, polypropylene -
UL 94 V-O/>28% L.O.I.
Safety Vent: Low positive pressure, self-sealing w/ flame arrestor
Float Voltage: 2.25 volts per cell ± 0.01 vpc
(Range: 13.44 to 13.56 volts per 6-cell unit)
Battery Life: 10 years in float applications
at 77°F/25°C
Dimensions: 22.00" (558.8 mm) L
x 4.90" (124.5 mm) W
x 11.75" (298.5 mm) H
Weight: 115 lbs.
3. Description/Condition:
New. Never been used, but have been sitting up for a little bit. Resting at 12.5+ though.
4. Price: :
$150 + shipping. Shipping is a beeotch though since these things weigh 120#. The estimate I got for shipping is $120, but I may be able to find a better deal. I will charge actual shipping.
Trades are welcomed.
5. Pictures:
Link to the same batt on eBay.
DEKA UNIGY BATTERY 12AVR-150ET (12V, 150 C/8AH) - eBay (item 200449576968 end time Oct-08-10 21:25:30 PDT)
Pics...
IMG_0667 by TaylorFade, on Flickr
IMG_0668 by TaylorFade, on Flickr
TaylorFade
I fail.
TaylorFade
Baton Rouge, La.
surreal
