Deka intimidator 9a31
any ideas on what my voltage might go up to?
It drops down pretty low at around 9-11v usually. measured with a fluke the amp draw is about 240a-250a. I have gain and bass boost set to minimum.
this is with stock electrical, only big 3 done, running 1/0 gauge wire.
wanting a 220 or bigger alt, and mayb 2 of the dekas.
yehhh i like my 2
If i full tilt my ab500.1 @ .5 ohm they mighttt touch 10.9....but thats stock alt and one run of 4ga wire
What are you doing!!!Your starving that amp!It needs at least 1/0 and if your droping to 10.9v you might smoke the board.
Why buy such a nice amp then skimp on the electrical???
What are you doing!!!Your starving that amp!It needs at least 1/0 and if your droping to 10.9v you might smoke the board.Why buy such a nice amp then skimp on the electrical???
It does have have 1/0 going to it
Now i got a new ground and it rests at 13.5....car off....used to rest 12.6 car on...so it should go up now
treasony
89 Super Coupe
treasony
Evansville, IN
Skip01
