MyFartsStink
my farts stinky they are
I have been wondering this for a while. So if the cone is deeper, is there more cone area? Meaning more air movment?
x2I have been wondering this for a while. So if the cone is deeper, is there more cone area? Meaning more air movment?
that would be sorta difficult to produce...if it were true, wouldnt we see deeper and deeper cones instead of greater diameters?
15's that look like 5 gallon buckets.
This cant be totally true. Why do think they make domed, half domed, and several other designs for the top of the piston? certain designs affect the air being pushed in different ways.ok the air is pushed ine one direction.. so think of it like a piston. in the engine, will the piston be more effective or less by having a cone shape removed from the top? it still will displace the same amount..
^ 100 %This cant be totally true. Why do think they make domed, half domed, and several other designs for the top of the piston? certain designs affect the air being pushed in different ways.
the short answer is NOif the cone is deeper, is there more cone area? Meaning more air movment?
You are mistaken, and it is totally true. A piston's shape affects how much volume of air is left within the combustion chamber at top-dead-center of the piston's stroke. A flat-top piston will leave a larger area in the combustion chamber than will its domed counterpart. This means that given the same stroke (piston shape does not affect crank stroke length), the domed piston will compress the same amount of air/fuel mixture to a greater degree, thus 'squeezing' more energy out of it. This is not at all the same situation as a speaker cone's physical properties or desired results.This cant be totally true. Why do think they make domed, half domed, and several other designs for the top of the piston? certain designs affect the air being pushed in different ways.
