ddz1 getting hot
tjjohnson91
alright i have a dd z1 to .5ohm ....... i have 3 deka 9's and a 250 amp alt
when i turn it up pops off and turns on right away (clipping maybe?) but it has a clip light and it dot go off or anything. would it not show it in the light when that low of load?
volts dont drop below 12.8 at idle
what is the DC Resistance (DCR) of the speaker combination measured at the amp? disconnect the speaker wires and measure DCR with a DMM. 0.5 is a very low impedance load and you may be dropping lower than that at some frequencies, causing the amp to go into protect...
or you may have a few wire strands shorting out...
My Z1 would click off too if over-driven. I'm also not sure if they like low impedances for extended periods of time either. I suppose it depends on which edition of the amp you have.
tjjohnson91
tjjohnson91
welcome mn
tjjohnson91
