Sold Dd m1a
Mr.Ronin_2U
Banned
I just got the amp yesterday from someone on here,it works great. Here are the specs from the listing where i bought it.http://www.caraudio.com/forum/car-audio-classifieds/487513-sale-digital-designs-m1a.html
For sale digital designs m1a
For sale is a Digital Designs M1A mono-block amplifier. This amp was purchased from an authorized DD dealer brand new 1 month ago as a display model and it works perfectly and is in excellent condition. I would rate it a 9/10 easily if not better. Here are the specs for the amp.
Features:
Two Amp Linkable
High level inputs can be fed into RCA's
Terminal block power & speaker connections
Clipping indictator
Thermal protection
Reverse polarity protection
Speaker short protection
Low & High voltage protection
on/off Crossover Selector
Specifications
Input Sensitivity 0.2V - 8V
Variable High Pass Filter -
Subsonic Filter 10 Hz - 50 Hz at 24 dB/Oct
Variable Low Pass Filter 20 Hz - 200 Hz at 24dB/Oct
Clipping Display LED
Tested Voltage 14.4V
Tested THD 1%
Cont Power at 4 ohm 300W x 1ch
Cont Power at 2 ohm -
Damping Factor >250 @ 1 ohm
Cont Power at 1 ohm 1200W x 1ch
Cont Power at 4 ohm Mono 300W x 1ch
Cont Power at 3 ohm Mono -
Dynamic Power 2300W x 1ch
Efficiency thru Output >75%
Dimensions - mm 300 L x 235 W x 53.4 H
Signal to Noise 85 dB
Shipping Weight 12 lbs (5.443Kg)
225.00 shipped or will trade for 1500rms and i'll add a SHURiKEN SK-BT35
and for the exact same price too. fishy
Haha newbie stop post dumping,look at my itrader. Since your not smart enough to figure it out i obviously want more power and yes for the same price as i bought it,should i make it less since i had it one day? Kick rocks puuunk.
Mr.Ronin_2U
Banned
Mr.Ronin_2U
9515ROB
michigan born
    May 14, 2026
michigan born
    May 14, 2026
