yea but u have four lol im just hopeing this one dd with 3.5-4k of power will kill the two p3s becuase this guy brags like its the loudest thing in my town...
Umm, you will get loud off 700w. My enclosure was too large for the DD. I had it in 5.5 cubes tuned to I think it was 35 Hz. I did 141.2 with approx 700w in a trunk setup. Not to mention, I was using 1/0 welding cable for my power wire and an 8 awg wire for my ground. Battery was an HC 1400 under the hood, big 3 and was per db drag street b rules. I was up against some guy with an xB that had 2 12" JL W6 with a 1000/1 and I got 3 dB louder. I then upgraded to a better ground and put about 1.5k to it and it got quite a bit louder since I was able to turn the gain up from 1/8 to about 1/2.
Here is an actual vid of that meet, I have the green accord (though you cant really see the full vehicle nor the other car). It was funny because in the first few seconds the guy and his team were cheering thinking they were gonna get way louder than me. My amp had gone into protect for some reason at the end of the last run and i was shi
itting bricks that it wont work so i started off the volume real low, as you will notice with the low numbers...then i gradually turned it up. The n00bs were bumping their system showing off for a good half hour before the meet. They had some nice flex and I thought they would get louder. Guess I was wrong //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Also, I upgraded to a soundstream xxx 6500, mind you this is still with a 90A stock alt, the 1400 under the hood and 1/0 power and ground wire. I would say i was doing a good 144 or 145 so probably high 130's or low 140's. Voltage was probably in the 11's as well. You will, with ease, get MUCH louder than two p3's. Sh
it, I used to have a 10 that would probably get louder in a sealed box. Go pwnt that sumabish.
