snarl2004 10+ year member Senior VIP Member 437 0 mass Sep 2, 2007 #1 Whats the most power you would put to a 9515 with cf dust cap for daily use? for comps? Click to read more...
jmanpc 5,000+ posts CA.com Nostalgist. 16,929 8 Jacksonville, Fl Sep 2, 2007 #2 They publish power handling for a reason.
22mountaineer 10+ year member 6 /\ 2,847 0 North AL Sep 2, 2007 #6 They publish power handling for a reason. Click to expand... Good luck getting anything out of whats posted...
andytb 10+ year member CarAudio.com Elite 1,392 0 SANDUSKY, OH Sep 2, 2007 #7 hook it to a wall socket?
mike11202 10+ year member CarAudio.com Elite 1,737 1 DE Sep 3, 2007 #8 does posting dickhead responses make you guys feel good or somthing? rms is 2000watts.. try 3-4k for daily
KnOkIn It 420 10+ year member Poo Poo Broussard 1,730 5 St. Rose Louisiana Sep 3, 2007 #9 does posting dickhead responses make you guys feel good or somthing? rms is 2000watts.. try 3-4k for daily Click to expand... Ah what motor?Stuff has changed over the years. RMS rating is 1500wrms And they will handle 3-4k daily.
pike110 10+ year member Registered User 141 0 indiana Sep 3, 2007 #10 Its hard to put a solid number on how much power you can put on the 95xx series subs. If you set your gains properly, you can run anything from 1500 up to 3 or 4k. They can handle a bunch of power if you don't do anything silly.
C Cas 10+ year member Member 42 0 trinidad Sep 3, 2007 #11 they can handle a bunch of power once a clean signal is being sent....if a distorted one is sent...then ure sub will be more liable to blow
