Hey, just a quick question...I've got two 9512's wanting to know if i throw another 2500d into my setup would each sub be able to take the juice daily???? thanks for your guys response in advance!
i blew a 9512e on a 2500d @ 1 ohm, in a box similar sized to yours, but i beat the dogshit out of that thing... burned all the tinsel leads right in half //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
CRX, I got the DD 9512 F motors / G basket and soft parts Dual 4 ohm.....Hoping they can take it considering I just bought another 2500D to strap up to my current 2500d powering both of them....Anyone else with more input let me know please!!!!
BTW: RipDaJacka HOW THE HELL did you fit a 5cuft box into the trunk of our vehicles???? I could not find a way!!!!!
yes sir.....shit now that i think about it the subs are only going to be receiving 1700 rms correct???? dual 4 ohm can only be wired down to 2 ohms correct me if im wrong
You can fit big box's in the monte, you just have to do some fabrication...... I basically have the same subs... I am currently awaiting my 2nd 802sx to be replaced. But I will be running around 2k each.. I think you will be safe as long as you set your gains correctly.
with the right box and making sure everythings right you can do it, i had 2 crossfire vr2000ds on a 9515 and 9518 b4 the z1 on the 9518g now.....just be carefull.... i dont like 2 amps on one sub for the fact of gettin both exact with out a master and slave.....
id recone the sub to d 1.5 anyways if your gettin the z1...... i got mine at 1 ohm and its loud but itll play at .7 daily dunno if id try .5 daily tho........
recones are expensive thru DD man....ill throw 2ohms at it and call it a day....3400w @ 2ohm is good for my daily driver //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
