DD 9510G specs off their site..
iwearpro
Ok I just picked up a 9510 g and went to their site to get the specs on box specs.. Now for my AQ'S I used RE Audio's box calculator on their site cause I found it to be the most usefull.. Now when I plun in all the specs they tell you to use under the 9510 I keep getting like 58mhz tune..The 1.6 cubes with the Port Area (sq in) 32 ,Port Length (inches) 18 I keep getting 58 mhz tune..
Does someone else have a different calculator that they use when building?
the dimensions that I need are 28 wide by 13 high, by 13 depth...Give or take 2 inches or so... I was looking for around 40hz..
I will runs some calcs for ya. give me a few.
I assume the sub made it there OK.
Nope,just pre planning..lol...My cars still in the paint shop till morning so ill start on it this weekend.. Im sure it will be here Monday or so..
with those dimensions....i got a 2" wide port that is 17" long....tuned to 40hz and 1.796 cubes minus your displacement of the sub....
Ok I used those numbers and on re audio's site it shows 37.75 hz
I wonder which one is close?
iwearpro
iwearpro
Forsyth Il
JL Audio
