DD 1508 specs...
anyone got the dd1508 and have the spec sheet...i'm looking at trying to make a model to see if i should go 2 3 of them and be louder than my 1 18.
i use 2 set ups
1 is a dd 9515G off a saz 1500 at 1/2 ohm in 3 net at 40 hertz
2nd is 3 dd 1508 off a saz 1500 at .7 ohm in 3 net at 35 hertz
the single 15" is louder
i use 2 set ups
if there were 3 8's, that were 1500 rms apiece, it would be a better contest.
actually pretty fair
same car nissan 350z
same amp
same box dimensions
dd9515 g is getting 1500 watts which is rms recommended
the 3 each 1508 are getting 500 watts rms each recommended
same amp
same box dimensions
no. fair would be if each 8 received 1500 watts, same as the 15 is. you're at about the right cone area, but each 8 needs to handle 1500 watts to be fair. the 3 8's now would be comparable to a 500 watt 15.
same amp
same box dimensions
Only thing is the 500 watt rms is their minimum rating. The 1508's take 1000 a piece. Double the power to each woofer and I bet they would rival your 15
yeah 350z is correctkdc i get what you are saying but that is not a fair test
each getting their rated rms (which is what 350 was giving them) would be the fair way to test it
no. you need to push 1500 watts to the same amout of cone area as the 15, not 500 watts to the same cone area. i could be wrong, as i've never attempted to compare 8's to a 15. i have done this with single 12's and dual 8's though, and (2) 200 watt 8's is comparable with a 200 watt 12, in the same type/style of enclosure (there are obviously more factors than just power handling). this is obviously a really broad statement, and i'm not a mathmetician, but after a dozen different 8 inch systems, and 10 or so single 10/12 systems, my ears tell me that 8's need the power.
cj407
Banned
cj407
Orlando, FL
azimuth
vegang
vegang
