Dc audio 5.0k
joshy629
DC AUDIO 5.0K
as close to new as it gets. no scratches on the top or sides just were you screw it in and a few scratches from it being mounted
amps never seen below 13v and was ran off a mechman 280 amp alt 1 batcap 4k 2 stinger spv 2150s and 2 batcap 2ks
selling it because i bought a new car and need money for my car so im getting out of it for a while. SO NO TRADES PLEASE
Key Features
• 1 ohm stable
• Variable low pass filter
• Variable subsonic filter
• Variable bass boost
• Wired remote control
• Clipping indicator
• Dual 0 awg power and ground inputs (both must be used)
We recommend for installation
• 1 upgraded battery under the hood
• 1 extra 800ci battery in the rear
• Minimum of two 0 awg ran from the front battery to the rear battery
• Both 0 awg power and ground inputs on amp must have 0 awg ran to them for a total of 4 runs into the amp
• Upgraded aftermarket alternator
• Dash mounted voltage meter
Features Voltage 5.0kw
Output power (RMS) 4 ohm 14.4V 900W x 1
2 ohm 2,300W x 1
1 ohm 5,000W x 1
1 ohm 16V 6,000W x 1
1 ohm 18V 7,300W x 1
Input Sensitivity 6V~0.2V
Low Pass Filter Switchable
( @ 24 dB Slope) Variable Hz 35~250
Subsonic Filter Switchable
( @ 24dB slope ) Variable Hz 10~50
Bass Boost Variable dB 0-9dB
Frequency Response Hz 15-270
Signal to Noise Ratio dB 100
Damping factor 150
Efficiency @ 4ohm % Over 90%
THD @ 4ohms Less than 0.1%
Fuse Rating 500 Amps
Linked Fuse Rating 1000 Amps
Indicator Power Yes
Protection Yes
Clip Yes
Speaker & power terminal Mold Type Yes
Power Gauge 0Ga
Heatsink Length inch/mm 25.59"/650mm
Heatsink Width inch/mm 9.38"/66mm
Heatsink Height inch/mm 2.35"/59.6mm
1000 SHIPPED
THESE ARE 1500 NEW
NO TRADES NEED MONEY FOR MY CAR
FIND THE SUBS ON SUB CLASS.
joshy629
joshy629
lawrenceburg ky
joshy629
