Dc audio 3.5k
HI-C
Dc3.5k
9/10 only because it's used but in great condition.
Has one scratch on the side not that noticeable.
Items Features Voltage 3.5kw
Output Power (RMS) at 4 ohm 750W x 1
at 2 ohm 14.4V 1800W x 1
at 1 ohm 3500W x 1
at 1 ohm 16V 4000W x 1
at 1 ohm 18V 5100Wx1
Input Sensitivity 6V~0.2V
Low Pass Filter Switchable
( @ 24 dB Slope) Variable Hz 35~250
Subsonic Filter Switchable
( @ 24dB slope ) Variable Hz 10~50
Bass Boost Variable dB 0-9dB
Frequency Response Hz 15-270
Signal to Noise Ratio dB 100
Damping factor 150
Efficiency @ 4ohm % Over 90%
THD @ 4ohms Less than 0.1%
Fuse Rating 300 Amps
Linked Fuse Rating 600 Amps
Indicator Power Yes
Protection Yes
Clip Yes
Speaker & Power terminal Mold Type Yes
Power Gauge 0Ga
Heatsink Length inch/mm 21.26"/540mm
Heatsink Width inch/mm 9.38"/238mm
Heatsink Height inch/mm 2.35"/59.6mm
On you! !
HI-C
HI-C
Las Vegas
HI-C
