dB meter
speakerdude123
WA
I would like to have my subs metered, is there any program on line that I can download to see what my subs hit, or do I need to buy something, or what? I know you can buy these little cheap dB meters on eBay for like 30 bucks and they go to like 130dBs or something but I'm not sure if those are accurate.
I have WinISD, but I would like to have an actual physical tool that meters MY subs, not the specs(like WinISD)
Anyone had any experience with the "scosche spl1000" dB meter. It's like 30 bucks on eBay, that is about as much as I wanna spend on one of these bad boys. I just want an idea of how loud it is don't care to much if it is super duper pooper scooper accurate.
Will this give me an idea of how loud my sub is? Say with in 1-5dB's?
not very accurate at all and doesn't go very high
Check out some local stereo shops and see if they have a Termlab Meter
Or spend $600+ on a new one
Termlab is one of the only ways to get an accurate reading, it is the meter used by most all organizations
Whats your setup? I'm betting you will get a more acurate guestimate from guys on here then 1 those meters (thats right 1 those)
I'll tell you since its going to be as accurate as you can get for a meter that is 40 bucks. 130-140dB. That's your score. Actually, that will be more accurate than the ebay meter you were going to get.
Termlab isn't the only way
Well I have an AQ sdc2.515 in 4.4cubes after dis. @ roughly 33-34Hz....running it off a JH600 @ 2ohms 666rms (that's what the document had it rated at). It is in the trunk of a coupe.
Anyone have any guess-timate as to what it would be hitting?
132.9 would be my guess going by what you are saying. What kind of electrical upgrades do you have?
so first you ask if there's a program you can download that will tell you "what your subs hit" but then you say it has to be a physical tool...lulz
And stop trying to guess what kind of numbers he's putting up, it just makes you sound stupid. Equipment is only 1 variable when determining the SPL a system is capable of, the enclosure design & install has a lot more to do with it.
im not looking to seal off im trying to stay out of wall classes and plan on staying in trunk classes
15
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
speakerdude123
speakerdude123
WA
bubbagumper6
audiobaun
    May 19, 2024
    May 19, 2024
