DB Drive PT2000.1D
Team TH (Donny)
Team Truth Hertz
DB Drive PT2000.1D
This amp is a beast and can do much more than its rated power. The amp has a fan built under the DB Drive blue LED logo which is located on top of amp (DriveSink heat management system with internal fan-forced cooling). This Amp has two Power, Ground, and Remote wire inputs (DC - DC PWM power supply). Has variable subsonic filter (20-50 Hz). Continuously variable 12dB boost on bass EQ & 12 dB per octave high pass & low pass crossover (50-250 Hz). Line out for easy daisy chaining of amplifier RCAs. Direct connect integrated speaker & power wire terminals.
Amp always stays cool never have seen it so much as warm even at a .5 ohm load played daily. Amp was never abused, have used effective electrical upgrades when ran at lower than 1 ohm loads. Amp can be wired and played at .5 ohm daily all day. Amp can handle up to a .25 ohm load, though would recommend this for only tone bursts/competition while using efficient and effective electrical upgrades. Also the amp can run at 16v setups!
Have original DB Drive packaging. Amp retailed at $1599 and are rather hard to find perhaps sort of rare...
Weighs about 28 pounds.
Reason for selling: Only because in my next setup I plan on pushing about 6-8k RMS.
Condition:
9/10 Appearance
10/10 Performance
DB Drive Rated at:
2000 RMS @ 1ohm/14.4v
1000 RMS @ 2ohm/14.4v
500 RMS @ 4ohm/14.4v
I've seen clamped at using 50hz:
4128 RMS @ .25ohm/14.4v
3168 RMS @ .5ohm/14.4v
2304 RMS @ 1ohm/14.4v
1161 RMS @ 2ohm/14.4v
586 RMS @ 4ohm/14.4
..Remember this amp can run @ 16v without any problems!
$525 Shipped to your door!
Price above includes shipping to your door using FedEx Home Delivery. Item will be shipped out within 48 hours of received payment.
Well, since there hasn't been any serious buyers on the amp or the subs I contacted DB Drive and soon going to be ordering D 0.9 VC Team recone kits for the subs then probably going to keep the amp. So after I get the subs reconed I'll be looking to get metered.
Team TH (Donny)
Team Truth Hertz
Team TH (Donny)
Mattoon, IL
Team TH (Donny)
