Sold DB DRIVE 15" WD subwoofers
--Navi--
Me > Team PSI
Subs are in great condition minus some sawdust on the surrounds I will wipe off before shipping //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Subs were used for a weekend then removed to make room for other things. They are the dual 2 option and have original packaging to ship them in. These can handle some serious power for daily use and arent a bad option for SPL either.
Looking for $250 or best offer + shipping per sub
A7 7500.1
Specifications:
RATED POWER 14.4 VOLTS: 1 X 6500 WATTS @ 1 OHMS
RATED POWER 14.4 VOLTS: 1 X 4000 WATTS @ 2 OHMS
RATED POWER 14.4 VOLTS: 1 X 2000 WATTS @ 4 OHMS
Frequency Response: 20Hz ~ 250Hz
Signal to Noise Ratio: 100dB
Damping Factor: 250
Efficiency @ 4ohm: 85%
Low Level Input: 6V - 0.2mV
Low Pass Filter (@ 24dB Slope): Variable 35-250Hz
Bass Boost @ 45Hz: Variable 0-9dB
Subsonic Filter (@ 24dB Slope): Variable 10-50Hz
Phase Shift: Variable 0-180 degree
Master/Slave (Linkable): Yes
Remote Level Control: Yes
RCA Line Output: Yes
Working Voltage: 8.5 - 18 Volts
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif:eek:
--Navi--
Me > Team PSI
--Navi--
Victoria,TX
--Navi--
