Dayton Tweeters...or These Horns?
shalizi
i blew the 3 of the 4 tweeters that i had installed from my jl vr525 components and im at the point where i cant afford to spend big bux on audio any more so i just need some tweeters to sound good and be comparable to the JL's...dont have the 8004 orion amp anymore i have a crunch 800.4 amp which probably doesnt even put out half of what it says..so
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=275-035
Dayton ND20FB-4 Rear-Mount 3/4" Neodymium Dome Tweeter
Specifications: *Power handling: 15 watts RMS/30 watts max *VCdia: 3/4" *Impedance: 4 ohms *Re: 3.2 ohms *Frequency range: 3,500 - 25,000 Hz *Fs: 1,700 Hz *SPL: 93 dB 2.83V/1m *Dimensions: A: 1-9/16", B: 1-1/2" x 1-1/2", C: 1/2".
Compact neodymium motors have low stray field
Ferrofluid enhances power handling and helps damp resonance
Rear-mount design minimizes housing size
Center-to-center spacing as low as 1-1/2"
Great top-end air and sparkle
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=270-041
Goldwood GT-1016 2" x 5" Wide Dispersion Piezo Horn Tweeter
* Similar to KSN1016 * Power handling: 50 watts RMS/75 watts max * Frequency response: 3,500-27,000 Hz * SPL: 94 dB * Manufacturer model number: GT-1016 * Dimensions: Height: 5-3/4", Width: 2-3/4", Depth: 2".
It may be a smart idea to find out why exactly you are blowing the tweeters in the first place. If you amp is sending a nasty signal to them, you could blow a new another set of tweets just as easily!
shalizi
shalizi
Los Angeles, Ca
PremierAudio
