Dayton Audio Ultimax
The subwoofer does not seem to be designed for car audio. In a 1.5cu ft sealed box, qtc is at 0.95. PE's recommendation is 3.0 cu ft sealed box for 0.707 qtc alignment.
Perhaps the 10 inch version would do better. PE recommends 0.63cu ft box with f3 at 45Hz.
That's what threw me off with the 12. 3 sealed and 4 vented is PE's recommendation. I would like to try one in an HT setup though... They look impressive.
Recommended from Dayton Audio:
10": Cabinet recommendations: • Sealed 0.5 cubic ft. (net internal), f3 of 48 Hz with a 0.707 Qtc alignment • Vented 1.25 cubic ft. (net internal) tuned to 25 Hz with two 2" diameter by 20" long dual flared Precision Port tubes, f3 of 26 Hz
12": Cabinet recommendations: • Sealed 2.0 cubic ft. (net internal), f3 of 36 Hz with a 0.715 Qtc alignment • Vented 3.0 cubic ft. (net internal) tuned to 22.5 Hz with two 3" diameter by 20" long dual flared Precision Port tubes, f3 of 22.5 Hz
@zako ; @DoesDad ;
PRODUCT DETAIL
Model Number UM10-22
List Price $207.99
Color Black
Unit of Measure Each
UPC 844632099243
Warranty - Parts 5 Years
Warranty - Labor 5 Years
Product Shipping Weight (lbs.) 22.0000
PRODUCT SPECIFICATIONS
Speaker Type Subwoofer
Power Handling (RMS) 500 watts
Power Handling (max) 1,000 watts
Impedance 2+2 ohms
Sensitivity 83.4 dB @ 1W/1m
Frequency Response 25 - 1,500 Hz
Voice Coil Diameter 2.5"
THIELE-SMALL PARAMETERS
DC Resistance (Re) 3.3 ohms
Voice Coil Inductance (Le) 1.27 mH
Resonant Frequency (Fs) 26.2 Hz
Mechanical Q (Qms) 3.03
Electromagnetic Q (Qes) 0.54
Total Q (Qts) 0.46
Compliance Equivalent Volume (Vas) 35.11 liters
Maximum Linear Excursion (Xmax) 19 mm
MATERIALS OF CONSTRUCTION
Cone / Diaphragm Material Nomex Cone
Dual Voice Coil No
Shielded No
MOUNTING INFORMATION
Overall Outside Diameter 10.625"
Overall Depth 6"
Baffle Cutout Diameter 9.625"
---------- Post added at 12:32 PM ---------- Previous post was at 12:32 PM ----------
PRODUCT DETAIL
Model Number UM12-22
List Price $233.99
Color Black
UPC 844632099250
Product Shipping Weight (lbs.) 23.0000
Power Handling (RMS) 600 watts
Power Handling (max) 1,200 watts
Impedance 2+2 ohms
Sensitivity 84.7 dB @ 1W/1m
Frequency Response 20 - 1,000 Hz
Voice Coil Inductance (Le) 1.22 mH
Resonant Frequency (Fs) 24.9 Hz
Mechanical Q (Qms) 3.45
Electromagnetic Q (Qes) 0.71
Total Q (Qts) 0.59
Compliance Equivalent Volume (Vas) 71.64 liters
Dual Voice Coil No
Shielded No
Overall Outside Diameter 12.25"
Overall Depth 6.5"
Baffle Cutout Diameter 11.25"
I used their recommended enclosure specs and vent specs
AnthonyO
Budget Banger Connoisseur
AnthonyO
Minot, North Dakota, United States
AnthonyO
