dayton audio frontstage pics!
FarrisAudio
ky
Well i installed daytons in the doors in my truck. They sound really good!! Though they are only ran off my head unit now. For the price i dont think you could beat it
heres my mid- http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-305
tweeters- http://www.parts-express.com/pe/showdetl.cfm?Partnumber=275-035
and my crossover-http://www.parts-express.com/pe/showdetl.cfm?Partnumber=260-146
By farrisaudio at 2009-01-18
Not bad, cant beat it considering you have what less than $75 invested for the whole set?
I dont have any exp with those tweeters or mids, but looks good and as long as it sounds good to you. Good job //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You might want to look into that gap problem. Also if you can try to attenuate the tweeters some so that they balance out with the mid better.
Assuming you can fix the gap with a new xover. And get it tuned in to sound a little more balanced.
I'd say good for you for having a possible nice sounding setup on the cheap.
You might want to look into that gap problem. Also if you can try to attenuate the tweeters some so that they balance out with the mid better.Assuming you can fix the gap with a new xover. And get it tuned in to sound a little more balanced.
It's not really a gap problem as I descibed before. I think he is crossing that mid over too high....
3.5k is too high IMO.
Typically, you cross at 2x FS. I wouldn't run that mid that high as you run into beaming issues. So you chose between beaming or a gap.
I thought you were referring to the ohm load issue. I was thinking the same thing about the mids as well. I'll never cross a 6.5 above 2.5khz. Right now I have my mids and tweets x'd at 2.5khz with 24db/oct slopes. it sounds good, but I always find myself messing with different points and slopes...never really see a difference unless I'm playing them at really high volumes.
FarrisAudio
FarrisAudio
ky
okiedokie
Mike Mccabe
