Dayton 10" Shallow Mounts - amp?
sparg93
NJ
This is a very newb question..should I apologize in advance.
It states in the specs that its a Dual 4ohm Voicecoil...but its rating of 250rms was at 2ohms.
Would someone mind explaining that to me?
If I'm running x2 of these, should I look at amp ratings at 4ohm or 2ohms...or something different? How many watts would you recommend and at what ohm? (I will be using a professional installer so I don't screw this up)
Parts Express rates the subs power handling with the coils connected in parallel if the woofers are dvc units. thus the @2 ohm rating. Most if not all the speakers on the site that I've read specs on have been rated in this manner.
I'm not saying that it does, I'm stating that they (PE) rate the power handling of DVC drivers with the coils in parallel. Hence the OP's original confusion...
sparg93
sparg93
NJ
sparg93
