Sold dave_damage's Huge Soundstream, Premier, Elemental Designs, Battery Sale
dave_damage
Soundstream Nut Swinger
Here you go, just a few things I need to get rid of. Wish i had a use for this suff but its time to say goodbye.
Soundstream 404 $165 shipped
404
Rated Power (4 ohms, 12.6V) 50Wx4
Rated Power (2 ohms, 14.4V) 100Wx4
Maximum Rated RMS Power 400 Watts
Minimum Rated Impedance (per channel) 1 ohm
THD:
Signal-To-Noise: > 100dB
On Board Crossover, Slope & Type Variable-12dB/oct HP, 24dB/oct LP
Full Range RCA outputs Yes
Differentially Balanced Input Yes
Fully Balanced Studio Inputs Yes
Hawkins Bass ControlTM** Yes-Variable
LMBC Compatible Yes
Power And Ground Connectors (gauge) 8
Input Level Pots 4
Dimensions (W x D x H in.) 15x11-9.8x2-1/4
Brand New Old School Rubicon 600-4 $250 shipped.
600-4
Rated Power (4 ohms, 12.6V) 80Wx4
Rated Power (2 ohms, 14.4V) 150Wx4
Maximum Rated RMS Power 600 Watts
THD:
LMBC Compatible Yes
Power And Ground Connectors (gauge) 4
Input Level Pots 4
Dimensions (W x D x H in.) 17-1/4x11-3/8x2-1/4
Soundstream Tarantula T4 12's (Pair) $280 for the pair or $140 each shipped. BNIB
3 Used Soundstream Van Gogh 12's $80 each or $220 for all 3 shipped
Proprietary Cast Aluminum Basket
UDV Cooling Technology
Low Distortion Nomex/Honey Comb Cone
Black Progressive Roll Conex Spider
C-Lock Rubber Gasket
XLS Santoprene Surround
Dual 4-ohm Voice Coil
2.5” TIL Glass Fiber Coil Former
Woven Tinsel Leads
Vented & Extended Pole Piece
Low Carbon Top & Bottom Plate
Rubber Magnet Cover
Specifications
RMS Power (Watts) 600
Voice Coil Diameter (Inches) 2.5
Magnet Weight (Oz.) 120
Freq. Response (Hz) 22 - 1.2k
Fs (Hz) 29.0
Qes 0.474
Qms 8.032
Qts 0.448
Vas (Ft3) 1.81/48.49 liters
Xmax (Inches) 0.649
SPL (dB) 87
Hole Size (Inches) 11.25
Woofer Depth (Inches) 5.9
Recommended Enclosure (Ft3) 0.6/0.8
Recommended Enclosure Type Sealed
Soundstream 12in Speaker Grills $30 each or $50 per pair.
BNIB Elemental Designs 13.0v's $100 each shipped These are the D4's
Old School Pioneer Premier TS-W1240C Single 4ohm coil $80 each or $210 for all 3. If local add $30 and you can have the box to.
don't feel like reading through all 11 pages. do you still have the 19ov2 and how much power does it take?Are you willing to ship?I know it said you didn't want to but just wondering if you still had it if you would consider it.
dave_damage
dave_damage
Gary, Indiana
dave_damage
