Sold dave_damage's Huge Soundstream, Premier, Elemental Designs, Battery Sale
dave_damage
Soundstream Nut Swinger
Here you go, just a few things I need to get rid of. Wish i had a use for this suff but its time to say goodbye.
Soundstream 404 $165 shipped
404
Rated Power (4 ohms, 12.6V) 50Wx4
Rated Power (2 ohms, 14.4V) 100Wx4
Maximum Rated RMS Power 400 Watts
Minimum Rated Impedance (per channel) 1 ohm
THD:
Signal-To-Noise: > 100dB
On Board Crossover, Slope & Type Variable-12dB/oct HP, 24dB/oct LP
Full Range RCA outputs Yes
Differentially Balanced Input Yes
Fully Balanced Studio Inputs Yes
Hawkins Bass ControlTM** Yes-Variable
LMBC Compatible Yes
Power And Ground Connectors (gauge) 8
Input Level Pots 4
Dimensions (W x D x H in.) 15x11-9.8x2-1/4
Brand New Old School Rubicon 600-4 $250 shipped.
600-4
Rated Power (4 ohms, 12.6V) 80Wx4
Rated Power (2 ohms, 14.4V) 150Wx4
Maximum Rated RMS Power 600 Watts
THD:
LMBC Compatible Yes
Power And Ground Connectors (gauge) 4
Input Level Pots 4
Dimensions (W x D x H in.) 17-1/4x11-3/8x2-1/4
Soundstream Tarantula T4 12's (Pair) $280 for the pair or $140 each shipped. BNIB
3 Used Soundstream Van Gogh 12's $80 each or $220 for all 3 shipped
Proprietary Cast Aluminum Basket
UDV Cooling Technology
Low Distortion Nomex/Honey Comb Cone
Black Progressive Roll Conex Spider
C-Lock Rubber Gasket
XLS Santoprene Surround
Dual 4-ohm Voice Coil
2.5” TIL Glass Fiber Coil Former
Woven Tinsel Leads
Vented & Extended Pole Piece
Low Carbon Top & Bottom Plate
Rubber Magnet Cover
Specifications
RMS Power (Watts) 600
Voice Coil Diameter (Inches) 2.5
Magnet Weight (Oz.) 120
Freq. Response (Hz) 22 - 1.2k
Fs (Hz) 29.0
Qes 0.474
Qms 8.032
Qts 0.448
Vas (Ft3) 1.81/48.49 liters
Xmax (Inches) 0.649
SPL (dB) 87
Hole Size (Inches) 11.25
Woofer Depth (Inches) 5.9
Recommended Enclosure (Ft3) 0.6/0.8
Recommended Enclosure Type Sealed
Soundstream 12in Speaker Grills $30 each or $50 per pair.
BNIB Elemental Designs 13.0v's $100 each shipped These are the D4's
Old School Pioneer Premier TS-W1240C Single 4ohm coil $80 each or $210 for all 3. If local add $30 and you can have the box to.
dave_damage
dave_damage
Gary, Indiana
dave_damage
