dash lights out after installing new deck?
adrock131313
I installed a new head unit in a 2001 accord today and just got a call from them saying thier dash lights were out. fuses check out ok. i used a wiring harness. The only thing i can think of is the orange illumination wires? but why would that take out the dash lights? any ideas?
Because you connected the illumination wire from the new head unit to the positive dimmer wire (which is controlled by a potentiometer and changes the light intensity for your dash and HVAC controls' backlighting) rather than the negative where it needed to be?(I think is how that goes...)
ok now you have me really retracing my steps . . . i had 3 orange wires . . . 2 from the new deck? one from the harness? guessing here i was in a hurry. i MAY have tied them all together not paying attention . . . but that would leave one orange wire unused?
Should have been one from the new deck and two from the harness and if you tied all three of them together then that certainly would explain why your customer has no dash lights //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
ok lets say thats the case (it just may be) what do i do with that third wire? why have i never had this prob before??? //content.invisioncic.com/y282845/emoticons/blush.gif.99bc659ee2012b7d826165e26fb5eebe.gif
If there are two wires coming from the car harness, chances are one of them is positive and one of them is negative. Tying them together will cause a short and most likely blow a fuse. If you cant find one blown in the fuse block in the car, check the one under the hood. As far as what to do with the extra wire, I just put a butt connector on the end of it and tape it together with the rest of the wires.
I had my sytem swapped over from my Trooper to my X-Terra and the same thing happen. No dash lights. Thanks for the info dudes,now I can go try to fix it. I even had the system install at a audio shop. Seems they would kinda no better. Later.....
well at least i don't feel like such a noob other people are making the same mistake //content.invisioncic.com/y282845/emoticons/blush.gif.99bc659ee2012b7d826165e26fb5eebe.gif still pisses me off that i did it //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
adrock131313
adrock131313
cleve, oh
adrock131313
