Damplifier Pro question
leastbay
I bought 15 square feet of this stuff to try out, i want to put it in my doors during my 6.5 component install, its 9 seperate sheets of the stuff, being I have a limited supply what part of the doors would be best to start with? the plastic door panel?
I would use it on the metal of the door first especially in use to help seal any holes in the inner door skin. I think that'd net you the best effect. Might be a good idea to slip some in on the outter door skin before you seal it off as well.
If you are truly going to seal the doors then I don't think you have quite enough.
I would not want to seal the doors until I had done everything to the outer door panels that I was ever going to do. So, I would put my efforts toward the outer door skin first. Then on the inner metal door. But that is about all you will have before you start running out.
leastbay
leastbay
New Orleans
WhoSayWho?
