Damplifier Pro first or Spectrum first???
I've actually asked the Second skin rep and he said it doesn't matter which goes first but if you do the spectrum first it needs 30days to cure before you lay anything on it. Thats why I know becuase I hate the look of spectrum would much rather have damp pro foil look.
Sweet more deadner going in tomorrow then.. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Going to pick up 200ft more.. I will do deadner then Spectrum then Over Kill Pro 30 days later where needed and Luxury Liner Pro to finish it off.. That should be more then good I think..
Spectrum is actaully an undercoating. Many of our customers use Spectrum on top of Damplifier only becuase they do not want to use it under the car like it is intended.
Damplifier inside the car.
Spectrum under the car.
This will sandwich the floor bettween the 2 different vibration dampers.
If you want to start reducing Airbrone noise, use Luxury Liner Pro on top of the Damplifier.
Spectrum on top of Damplifier will help increase the results from the Damplifier, but not nearly as much as some of our competitors might have you think.
The only Time I use Spectrum inside the car, is if I want to hit all the areas I missed with Damplifier Pro. Then it help pick up hard to reach surface area.
ANT
RetroAudioinc
Custom Car Audio Decals
RetroAudioinc
Indianapolis, IN
Anthony Collova
