Dampening Material ..
Well ... i went to a parking lot this afternoon and tried to see if i heard any rattling etc.. and i heard a lot coming from my trunk .. soo .. i think i might just second skin my trunk and maybe put some overkill in there too .. since i dont want the tin foil look .. but on the other hand .. it would act as a great reflector when you get a flat tire .. in the night .. of course
I've used 36 sq ft in my small SUV rear doors and hatch door, then sprayed several coats of SS spectrum on top of it... the first 36sq ft was Dynamat X ( got it for $110 for bulk pak), Got some Raamat coming this week and I noticed it's thinner but I can always double or triple it, since I like 3 layers or so on outer door and atleast 2 on the inside door, but be careful that you don't over do the inside door or you can not get the door panel back on...
The SS spectrum worked wonders on the doors, each must weigh like 5 lbs or so more than a factory door.
See ya!
get a roll of raamat, and some of the closed cell foam... the aerosol spray adhesive they have works better than most other products so order it at the same time.... while ur waiting for it to get to ur door make sure you go out and get urself a good heavy-weight roller to apply it
How much you buy dependson what you buy.
If you go with Dynamat extreme, you could use 2 bulk packs (72 sq feet) and be good.
Rammat, you may want to go with 100 - 120 sq feet.
Edead 160-180 sq feet
peel and seal 160-180 sq feet.
Somthing like that.
ANT
DjiNN
Posts but still a NooB
DjiNN
Brooklyn, NY
Anthony Collova
