bad03ranger 10+ year member
Get Some *****
i have pioneer 5x7s and i am in the process of putting a sub system in but i want to cut lows out of the spkrs w/o amping how do i do this
i do have a aftemarket HU but it seems to sound better w/ the EQ off but i may play around with itif you have an aftermarket HU theres a setting on most where you can turn the lows and bass out of them. if not bassblockers are you solution
Don't bother cutting out any higher than 90Hz on those, otherwise you'll have a band of frequencies that no speakers/subs will be playing, which is bad, because that range is what some people on here will call midbass.i do have a aftemarket HU but it seems to sound better w/ the EQ off but i may play around with it
would the best one to get be the one that cuts out 0-300Hz?
the lowest BB i could find was 150Hz will that b prety good then unless someone can tell me another place to get themDon't bother cutting out any higher than 90Hz on those, otherwise you'll have a band of frequencies that no speakers/subs will be playing, which is bad, because that range is what some people on here will call midbass.
