Sold Custom Powermaster Alternators
SPL2k
I hate to do this but I have no use for these and probably never will. atleast not anytime soon.
2 Powermaster XS Volt 350's that were custom hand built specifically for me by the head engineer at Powermaster. (Coy Hudnall) They have internal adjustable regulators with the fastest reaction time in the industry. Adjustable from 12 to 20 volts. "Self exciting" so no wiring is needed other than the 1/0 for charging. They are brand new. Never installed or used.
More info and specs here.....
http://www.powermastermotorsports.com/spl_alternators.html
These are intended for SPL only vehicles. I would rather not break up the pair but i will if i have to.
$900 shipped for the pair or $500 shipped each.
Yes they will work in a daily driver but they have very limited or no output until they get to around 1200 RPM. Most SPL vehicles idle at 1200+ RPM compared to 700 or so in most daily drivers.
No i dont...sorry.
The pulleys can be changed though on the alts if its not the right ones. Just go count the ribs on your pulleys in the 4Runner and compare to the pics.
If you know somebody at Boston Acoustics I may have something you'd like. One complete set of Boston Acoustic Z 6s including x-overs and grills. In need of repair was running through x-over on head unit and it got turned off. Somehow one of the tweeters is fine and one of the mids works also but like I said if you have a connection at BA this $1,000 set of components may be up your alley?! Worth a shot I would love one if not both of your alts if we could work out a deal. Looking for 350 credit for my Z6s. Please reply in PM if intersted. Thanks in advance ..............................................Joe Rod
These are GM large case alternators. They will only be a direct replacement on some gm tucks, vans, and full size cars. They will work on any car or truck out there but most will require a different belt and modifying your factory alternator bracket. (fairly easy)
SPL2k
SPL2k
Lake Havasu, AZ
pd8731
