Will only fit Mitsubishi Montero Sport / Pajero.
Replaces front floor storage compartment in cargo area. Direct replacement: simply un-bolt the 4 bolts on the factory compartment, un-clip rear seat carpet flap, and bolt this down using the 4 factory bolts. Top cover has dual 12V 80mm fans that pump fresh air into the compartment. Compartment is designed to allow flow of fresh air over amplifier heat sinks then force the heated air out the sides to dissipate throughout the floor chambers of the cargo area.
Attached carpet is in pretty good shape but to look new, you may want to peel it and replace it on the cover. This is super-easy, being only a single-surface. Also, if your interior is a different color, the carpet can be matched for stealth.
$100 + over-size shipping (will have to ship in a LCD TV box to fit). Questions, please ask.
Thanks
Amp rack:
Amp rack with false floor "lid" on top:
Included parts: riser blocks (use if you want), relay (turn on fans with amp turn-on), and fans. Also showing under-side of the "lid"
Initial installation:
False floor carpet cut away from fan holes for better flow, rear seat down.
Lid propped open a bit:
Amp rack with false floor lid removed:
Thanks
Amp rack:
