Custom fiberglass center console for 8"sub
2007rustanggt
If i build a center console from scratch for an 8"sub (not decided on driver yet) does the shape matter? Like if it is l shaped with the driver at the 90° bend will it sound bad? Looking for sq. here not overpowering bass as the driver will be pointing in between the front seats at dash.
It will more then likely alter the response curve, but more do to loading and such rather then the physical shape.
try it and see how it works for you. I have heard thousands of mix reviews on similar enclosures even ones I have done. Some love them, so do not...boils down to you personally.
I have a ported Tang Band 8" in my center console. I used it as a sealed sub before and was not happy with the output. If it is possible to use a ten or 2 eights - I would suggest it.
2007rustanggt
2007rustanggt
Fort worth, tx
2007rustanggt
