Custom box, made specially for JL 10W7's
DanCap
Just got my box in today!
It is hand crafted from Av Priority Custom box builders out of New York!
This is a custom box designed only for 2- JL 10W7's, I was impressed with the flawless design!
Just look a the pics, can't wait to get this system bumping!
It was 245 shipped! Its a guy that builds boxes specially for Jl subs located in NY.
Great quality! my 10w7's should be in next week, i will put up a sound clip when its installed, should bump!
Those ports look skinny but there really not at all, and if i had a picture that shows the back of the inside of the box the ports go through like a zig zag, something different, but i like it!
It features ported design construction using 3/4" MDF for the main enclosure along with the internal bracing and 1" MDF front baffle's for mounting the subs. The gross internal volume per side is 1.58 cu.ft.
The use of the internal bracing strengthens the enclosure substantially for an enclosure that is truly rock solid. Each brace is fitted into dado's on all four sides to further add strength.
This is a real beast weighing in at 68 lbs. Box dimensions are as follows:
35 3/4" wide, 16" high, 16" deep.
DanCap
DanCap
Jackson, NJ
djman37
