3 custom aluminum blocks. 2 for fusing, 1 for ground distribution.
i built both of these. three blocks total. 2 obviously used for fusing. room for 4 anl fuses, one has a tight fit but still fits. will fit 4x 1/0 inputs and outputs. and the ground distribution block will fit the same, 4 in, 4 out. tapered so most 1/0 wire sheathing will fit into it as well. the aluminum is 1" solid thickness, already pre-drilled and tapped for the proper hardware. works very well, im just moving to a smaller setup and wont need these anymore.
each block is 6.5"x4.5"
fuse block is 75 plus ship. ground block is 40 plus ship.
shipping will most likely be flat rate due to the fact theyre not too large.
