Custom 10" Kicker l5 Box
99CherokeeSport
Ok, I'm making a box from the free box design sticky, and I was wondering how to know what Hz to set the box at.The specs on the kicker say Resonance Frequency[Hz] 33.3 and minumum cu.ft for a vented box is 1.25 and the max for SPL is 2.25 so if I want it for good sounding bass would a box of 2cu.ft @ 32Hz be good?Or would a box of 1.75 cu.ft at 28hz be better?Im a newb and this is going to be the first time building a box for my subs.Thanks
Thanks, and as for the cu.ft would 2@32 be a good match for the sub.Sorry for all the ?'s Also I have two of these so would it be beter to make two boxes or one big box for both of them?
i would do one box with a divider so it will be two chambers and do subs in the middle and a port for each chamber,
that way if you blow one sub you can still use the other one while you get the blown sub replaced/repaired
99CherokeeSport
99CherokeeSport
Laredo,Tx
splescort
