Current Flow
Direction of current flow
  • Total voters
    31
Wanted to know how many of you know which direction current flows. Take the poll, i'll post the correct answer in a few days.
i believe it's actually neg to pos even though most people think it's the other way around
It flows Negative to Positive in DC current and Positive to Negative in AC current.But I could be wrong.
Technically, in terms of momentum and the like, the electrons "pull" the protons. Thus, in terms of polarity, it flows negative to positive.
But, for whatever reason (probably a cruel joke by the founders, or maybe just ignorance at the beginning.) They called the true negative pole "Positive" and the true positive pole "Negative."
So, it flows positive to negative in common terms, but in terms of physics, negative to positive.
THUS THIS IS A TRICK QUESTION LOLZ
Opposite flows of opposite charges contribute to a single electric current. Negatively charged carriers (Electrons) will flow towards the positive pole and positive charged carriers (ex. ions) will flow towards the negative pole. In wires the postive charge carriers are immobile and only the electrons flow. The electron motion is opposite the direction of the conventional current. Inside lead-acid batteries: electric currents are composed of positive hydrogen ions (protons) flowing in one direction, and negative sulfate ions flowing in the other.
See what 5 minutes of research turns up.
Technically, in terms of momentum and the like, the electrons "pull" the protons. Thus, in terms of polarity, it flows negative to positive.But, for whatever reason (probably a cruel joke by the founders, or maybe just ignorance at the beginning.) They called the true negative pole "Positive" and the true positive pole "Negative."
It was out of ignorance .......
DBBOOM
DWN4MYN
DBBOOM
eastcoast
boomin spl
