curious question for ohm loads
HemiRT
8
ok so i should probably already know this since ive had several audio systems but here it goes. ok so considering a new amp setup (i have an alpine m-1000 amp currently) i was thinking if there was another way to wire my subs to lower the ohm rating would i be able to get more power. right now i dont remember if i wired my subs, which are 2 type-r (2 ohm), in a parallel or series wiring. doing the math if it were in a parallel series id be at 1 ohm total. if it were in a series it would be 4 ohms total if i did that correct. so that means the wiring would make a world of difference in how much power i am supplying my subs. anyways so, if they were wired in a series and not parallel would my amp be able to handle that increase from say powering only 500 watts total to over 1000. i looked at m1000 ratings on the internet and it said "RMS Power Rating:
4 ohms: 600 watts x 1 chan.
2 ohms: 1000 watts x 1 chan."
this would mean that it actually puts out an overall rating of 2000 watts if wired in a certain way right (parallel w/ (2) 2 ohm subs)? could it handle that?
thanks
i was under the impression for parallel wiring it is (Speaker A x Speaker B)/(Speaker A + Speaker B) = total ohm rating. 2x2/2+2=1 ohm. Is that not possible to achieve?
that site is wrong lolz
here:
"RMS Power Rating:
thanks
^ I coppied this from your post
the big thing about it is that you are giving off power ratings by 1 channel
like bridged ? or is your amp a mono ( only one center channel - no left or right )
because if its a 2 channel amp - and each channel gives 1000w @2ohm rms it is a beast of an amp.. lol
im 90% shure that the most power you can ever achieve from this amp is 1Kwatts @2 ohm load with propper electrical to back it up. running a 1 ohm load to this amp is mostlikely a bad idea also.
RMS Power Rating:
4 ohms: 650 watts x 1 chan.
2 ohms: 1300 watts x 1 chan.
1 ohm: 2000 watts x 1 chan.
id have to imagine that the power ratings on the 2010 models are a little over rated but not by a ton. I realley liked my hifonics bxi 1206d when I had it.
you say ur subs are 2ohm coils ? are they single or dual ?
because if you have dual 2 coils then you can only wire to a 2 ohm load for your amp.
as I dont think it will take .5 load and last at all for music daily
but
if your subs are single voice coil 2 ohm then you can wire em down to 1 ohm load eazy as pie and recieve more power from your amp.
HemiRT
HemiRT
HemiRT
