CT sounds????
  • 6
It certified at nearly 1700 at one ohm on 14.4 (car running). Based on the 300 watt delta from the 12.8 a non scientific guess is 900-1000 watts. When the dust settles That’s kind of an expensive 1000 watt amp
Says 700w rms @2ohm so it would be even less than that maybe?????
those are 12.8 volt ratings. At 14.4 it shouldn’t be less the 700w rms @2ohm, it should be more around the 900 to 1000w range
Both you guys don’t read good. Last sentence in my last reply....hence why I said expensive 1000 watt amp.
No, I totally understood what you said. I was just relaying your message. I guess yeah, it is expensive. Hopefully the price tag is justified due to quality. It looks like a nice amp, that has some nice features, like for one thing the ct1500.1d has undersized terminals (squeezing 4gauge in wasn’t the easiest) the at1400 on the other hand has what looks like zero gauge power/ground terminals.
I was able to log in fine, using Chrome if that helps. I don't know anything about the product at all, just found the info and shared the love. :)
595
Brother in law has some of their 8’s and they are little beasts. Typical cookie cutter product that performs as it should.
Off the shelf design, nothing special and will sound like a bull horn. The best pro audio drivers I’ve heard are the crossfire XTpro6’s. The best...
Timbo74
CarAudio.com Regular
Timbo74
Wisconsin
BCotrell
    May 18, 2024
    May 18, 2024
