N Natebratt21 Junior Member 15 0 Peoria il Jun 27, 2017 #1 Has/ does anyone use this amp? I have been searching for reviews can't find any. Gonna be powering two nvx subs, 700 watts at 1 ohm Sent from my iPhone using Tapatalk Click to read more...
BOOMINGRANDPA 5,000+ posts WOLFRAM FTW 7,109 53 NC Jun 27, 2017 #2 they are the 350 rms nvx? ct has had some good reviews (50 on amazon) then saw something about amps having vibration problems idk.. u can get ppi like mine little cheaper tested out at 1162rms @1 ohm, many peeps here run the 2 and 4 channel versions of it on mids even those with well over $5k worth of equpiment (1 guy probably has that much in wire and batterys etc, he has 4- 2 channels ppi).. https://www.amazon.com/CT-Sounds-T-1000-1-Monoblock-Amplifier/dp/B00TRLD5KK/ref=sr_1_1?ie=UTF8&qid=1498618675&sr=8-1&keywords=ct+sounds+1000 if u get the ppi don't get it from jbtools go to other seller car audio closeout maybe https://www.amazon.com/P1000-1-Precision-Power-Monoblock-Amplifier/dp/B005KW10ES/ref=sr_1_fkmr1_2?ie=UTF8&qid=1498618874&sr=8-2-fkmr1&keywords=precision+power+p1000
OP N Natebratt21 Junior Member 15 0 Peoria il Jun 28, 2017 Thread Starter #3 Okay! Thanks man I appreciate the reply! Sent from my iPhone using Tapatalk ---------- Post added at 11:19 PM ---------- Previous post was at 11:18 PM ---------- & yeah the 350 rms nvx nsw 124's Sent from my iPhone using Tapatalk
kr15 5,000+ posts Polluting Residentials 6,702 56 California Jun 28, 2017 #4 The vibration stuff really wasnt on the smaller amps. And the T line is newer i believe. Guts look adequate. There are other proven options like the PPi and others. But im sure the CT would do fine
OP N Natebratt21 Junior Member 15 0 Peoria il Jun 28, 2017 Thread Starter #5 Alright Thanks for the reply ! Sent from my iPhone using Tapatalk
