CT Sounds 500.2 Amplifier - 1600w RMS at 4 ohms
cthedinger
Brand new CT Sounds 500.2 Amplifier
Brand New
0GA Inputs
Clear Plexi Glass Bottom
CT Sounds Voltage Bass Knob Included
Class AB
520w x 2 at 4 ohm
800w x 2 at 2 ohm
1600w x 1 at 4 ohm
Link for more info
https://www.ct-sounds.com/products/discontinued/ct-500-2.html
$199.99 shipped
Free Shipping via FedEx Ground. I can take payment by PayPal or Credit Card. PM me to order.
You can check my previous transaction feedback here:
cthedinger
Would these be too much for 1set of meso 5.25 comps per channel? Kind of want a good amount of headroom. What's the current draw and warranty? Excited fort 2nd meso comps to come in.
For the Meso 5.25" I would check out the AT-125.2 we have on special. It would be a better match for your speakers.
https://www.ct-sounds.com/products/amplifiers/at-series/at125-2-amplifier.html
All our brand new items have a 1 year warranty unless specified otherwise. Also make sure you buying from an authorized source.
Well I'm running 1 set per door and with what I'm planning it might not be enough. I got my comps from you on Amazon. The 125 will run two sets?
Yeah 1 should run 2 pairs but if you are wanting louder then I would probably get (2) AT-125.2. I think those would be a better match for your speakers than the 500.2. The 500.2 is good set ups using 8+ speakers or for running subwoofers.
What is the RMS on those? Also what ohm load are they?
300 rms each 4 ohm so would only be 100 watts ish over powered but the enclosure they are in would be slightly small with a higher high pass on them so pretty sure they can eat it all up just fine. IF not, i'd still rather have headroom and let the amp cruise by with a lower gain setting than an overworked small amp.
2 of these would be sick on my front stage. One speaker per channel with 1 amp per side. 520 on a tweeter, hell yes
aint that a lil too crazy for one pair of hertz tweets.
We are almost out so hurry and order. I have sold 5 already today (Over 100 in the last 2 months) and only have maybe 20 left.
300 rms each 4 ohm so would only be 100 watts ish over powered but the enclosure they are in would be slightly small. But i'd rather have headroom and let the amp cruise by with a lower gain setting than an overworked small amp.
Wire each pair down to 2 ohms and call it a day. 800w rms x 2 at 2 ohms
Sounds fun.
cthedinger
cthedinger
Inglewood, CA
FineLinePimpin
