CSS SDX15: 4 cubes @ 25
Looking good. I wouldn't worry much about having noise because of signal wires being close to power wires. I've never had that problem before.
I'll be shipping the scraps out tomorrow; I've been busy the past couple of days.
Well, I didn't quite make my deadline, but it was **** close. Mounting posed unseen problems, as I had to mount it vertically due to the design. I used the port cutouts to pile wood inside to rest the motor on until I had started a few screws.
The security screws I have aren't long enough, so now I need to order some online. It will give me the time I need to get two screws in that are giving me trouble. I just have flatheads in there for now.
I think even without the security screws, this thing will take some time to dismantle. I may take the time to add more bolts on the back end of the box since the one in the amp rack are so close to the edge. But that may involve getting it up on the lift and moving my tank out of the way for a bit.
Wtf...****ing cats:
Torquing down the amp panel bolts pulled some of the inserts out, so I tapped some washers and screwed them in around the inserts. Now they aren't going anywhere:
Installed mids:
Amp panel (I may add white cathodes to the box in the future, since I have the relay for it wired already):
And out back:
Nice and clean:
Pics make the color look a little off. It's much closer in person:
I had trouble with 2 holes, so i just put some gasket caulk/tape stuff in them and it works leakfree for now:
Right before I closed it up:
I'll have to get some better shows during the daytime, but I think you all get the idea.
Could u please give a review or some sort of opionion on how the sub performs? i'm very very interested in purchasing one in the near future and would love to hear some input on how it performs.
It'll probably be sometime Friday or this weekend. I just haven't had the time between work and school to get enough listening/testing time in as I would like. I also need to set the gain correctly on both amps. I basically just set them low and put everything in. Once I've played with it for a bit I'll sit down and set everything.
I was a little surprised at the coil impedance.. They're listed at 1.8, while they read 3.6-4.0 each. I know impedance rise will change the load, but this was fresh out of the box, and I've had other woofers read much closer to publish specifications.
Has the cloth come in? I'm assuming you're planning on using it for the front doors?
Just got it today. I'm actually looking to cover up the fans. Since apparently case fans don't reverse with reversed voltage, I had to switch one of the sets around, ruining my nice symmetry. So im going to cut some square rings to fit the holes and stretch the cloth over them. Hopefully it'll allow enough airflow. If not, I can always up the voltage. I think I have them at 6 right now.
Excellent work, looks awesome and original, looking forward for some reviews and vidz if possible, I was actually having an eye on that sub for home use.
Good job
me and my cousin installed my SDX15 this morning and it sounds amazing :). Its uber accurate and doesn't miss a note on metal songs with fast bass or double or triple bass. I've got mine 3.7 cubes sealed. Didn't make a thread since I have no pics and don't want to get stoned to death hehe.
hempy
bass wiener
hempy
nola
Mc_Hammer
