CSS SDX15: 4 cubes @ 25
On a side note, I think I found the source of the coil problem on my 18.
You have a beautiful puѕѕy. I would take the collars off as I can't stand petting a cat with one on.
Th...th... thank you? //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
A little change of workspace:
I decided just to glue the fans together:
New amp panel done and stretched. This one was kinda rushed but I think it turned out pretty good.
First fan mount cut:
I'm also looking for someone with some grille cloth scraps that they can send me in a regular envelope.
First testfit with fans:
Amp rack/box/thing:
Testfit after vinyl (even more snug):
Plexi installed:
Masked off for paint:
Nice braided pigtails:
I just stretched it w/o glue. I wasn't sure about how to do any vinyl work, so I asked the guy that runs a custom interior place behind our shop.
Wow, this is a really beautiful build.
I was looking into vinyling my next build. Are there any pointers that you could offer after working with it? Did you have any problems with it ripping at the staples?
There was a little, but since I had the staple line at least 1/4" away from the corner/edge, it didn't really cause many problems. I would suggest buying good vinyl, at least 2-way. I was strapped for time (trying to finish in my winter break) so I had to go with what matched best locally. The stuff I got sucks, but it worked out. Round edges are much easier to stretch around than corners.
Weeeelll...
I got the box into the car after work tonight. After this point all of the work will be done inside the car. I still have lots to do. Run new 1/0, route wires in box, screw in cable holders, run another 12v wire for the fans/relays, probably wire some sort of led lighting for inside, i still have fab work to do with the fans, too. So lots to do.
Sooo snug:
The amps may be a little crooked... I still need to nudge them around a little:
I did run into a possibly large problem today though. Right now I have 2 wire holes cut, one on each side, near the bottom. I made the box about 1" shorter than the space between my wells. Not enough space for wire on each side. Luckily I only cut the fabric out of one hole, so one side looks like there isn't even a hole. This works, but now I need my power/speaker/rca wires all to cross for about a foot. Is there any way to effectively shield my rca/speaker wires from thw rest?
I've also been thinking about the chinese finger trap type flex loom, but I can't seemt o find anything larger than 1/0...any suggestions? (I have split loom that will fit everything now)
Space to run all of my wiring //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
The carnage as of this evening:
Used some sealing washers on the terminal cup for a better seal:
My nifty securing/ground bolts:
Ground to bare metal then bolted down and undercoated:
Soon to be covered with techflex (hopefully with no noise):
hempy
bass wiener
hempy
nola
Mc_Hammer
AJ (ACE)
    Jun 28, 2026
