CSS SDX15: 4 cubes @ 25
hempy
bass wiener
I just got my CSS SDX15 yesterday, and I decided on a box. Originally I was going to seal it a fiberglass box w/ amp rack, but I hate having to deal with glassing in the cold and I don't have the time to finish within the break.
The recommended car box is 4 cubes at 25 hz with 2 4" aeros 20" long, walls lined. The port tubes I bought are 17", but I'm not sure if that represents the tube length or overall port length. I will need to add a 90* bend, so hopefully that wind up accounting for the extra length. I would be measuring the line down the center, right?
I'm going to have it firing at the read of my cherokee, with the ports facing back on the right side. I'm going to add on an amp rack on the back to keep everything clean, with beauty panels on the front and back. I have some leftover black PE carpet, but I may go with vinyl or something that looks more stock. I'll probably use black laminate on the front as well.
Double boxed:
Mmm... sexy cone.
Fat leads:
Woven in:
Lots of glue:
Cone:
More cone:
Even looks good from the back:
More cone:
No coil shot... //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
god i want one of those subs soooo bad //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif... seems like a killer deal for $290
i think i might snatch up one of these as soon as i can afford it
The build begins!
Wood:
Starting amp rack:
Bracing ribs (not sure if I want to use these or not...any opinions?):
Starting back trim panel (with my new xmas toys):
A clean workstation is a happy station:
1.5 extra sheets (has to buy more since I didn't know they were bowed):
Starting plexi rabbet:
Finished!:
Rough trim panel:
90* elbows for ports:
Plexi pilots drilled/countersunk:
I was originally going to use t-nuts for the trim pieces, but I may have to come up with something creative to get the thin middle parts tight. I'll probably just cut off 1/8" from some threaded inserts.
hempy
bass wiener
hempy
nola
Mc_Hammer
AJ (ACE)
    Jun 28, 2026
