Power Wiring Recommendation: The ZA1200 amplifier has four 40-amp fuses, for a total fuse rating of 160 amps. The power and ground terminals accept up to 4-gauge wire, and typical 4-gauge wiring kits include 100-amp fuses. In order to match (or exceed) the fuse rating of the amplifier, it is recommended that you substitute a 160-amp or higher fuse for the 100-amp fuse supplied with the amp wiring kit. An ANL fuse holder and ANL fuse may be required to meet or exceed the 160 amp fuse rating.
http://www.crutchfield.com/p_099ZA1200/Eclipse-ZA1200.html?tp=115&tab=detailed_info
//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
